floridaboater1
- May 20, 2010
- 80
I have a 1975 mercruiser 120 2.5 153. I rebuilt the engine when i took the cam out it was hard to tell where the mark was on the gear. So i put the engine a tdc. and i made a new mark on the cam gear for reinstallation. Well i put everything back together and it ran good no real problems. I put 20 hours on the engine then i pulled the timing cover to replace the timing gears ( i couldnt get them at time of rebuild) When i got the new cam gear i found out the i had been running the engine 180 out. I just installed the cam with the new gear correctly but now the engine wont run... If i spin the cam 180 out again it will run. what could be the cause? Why will it only run 180 out?
