CDI Tech Support
- May 14, 2010
- 127
Re: 75hp Mariner not charging battery anymore
Standard AC measurements only measure RMS. DVA must be used because it's accurate whereas RMS is not. A digital meter does have built-in DVA. A DVA Adapter must be plugged into a digital meter in order to read DVA (peak AC voltage).When you put the meter on the yellow don't forget to switch to A/C.
