Re: Correct prop
Your are about 1,000 rpm too low and going down to a 15 will only add ABOUT another 400.
With the motor off and in forward you need to open the throttle and look into the carb throat.You may have to remove the air box.
Describe the overall performance, how is the hole shot. what happens with say 4 or 5 people in the boat?Where is the antivent plate(just above the prop) in relation to the bottom of the boart.. below,even, above? a picture with a straight edge along the keel from the bottom to the plate showing the position would help.
