Re: 1989 Evinrude 140 Low RPM startup
I have an 1989 Evinrude 140 when I first start a cold motor it runs at a low rpm and wants to die if I let it go without giving any throttle it will gradually increase rpm to normal idle speed and idle fine. I will usually have to give it some throttle at cold start up so it doest try to die if I restart the motor right away it will start fine but if I wait over 30 min it will do the same thing. When I restart the motor right away it will start at a little higher rpm around 1200 then gradually slow to around 900 RPM. I have cleaned all the carbs and it still acts this way so I think they might be ok. Is the timing automatically retarded at start up to make for easier starting? Is there something on the timing which might need adjusting? I have an OMC service manual and after reading the timing procedure there seems to be quite a few steps which have to be done in sequence to get it right so I didn?t mess with it.
by "cleaning the carbs" did you rebuild or just ran some carb cleaner? if just cleaner then you might want to rebuild them.... "cleaning" doesn't always do a good job.... in my signature there's a good way to clean the carbs... give that a try, if that doesn't work rebuild them....
have you tried to pump the priming bulb while these symptoms occur?
last time spark plugs and wires were changed?
if you want to check the timing there's a procedure you can follow... look in the FAQ section.... and no, timing it is nor retarded...
when i start my motor cold, 120hp 1989 pretty much the same motor as yours, i usually give it some gas and let it idle around 1500 for about 30 sec to a min to get the motor warmed up... then i bring the throttle back and let it idle... should idle around 850 in neutral in water....
so, try priming the bulb while the motor is running... if that doesn't do anything for you try do follow the carb cleaning instructions.... check the spark plugs and wires... then check your timing...
if nothing worked i would rebuild the carburators and go from there...
good luck
