phwrd
- Jul 30, 2007
- 294
1. Please refer to the attached pictures. Is grease coming out of a new steering (Teleflex NFB) normal. This brand new unit has less than 10 total hours on it.
2. I took the boat (19.5 ft v-hull 140 hp Suzuki) out on Thursday, she 25 mph at 4200 rpm in a moderate chop. Took it out on Saturday and it ran 25 mph at 4800 rpm in a light chop. She ran at 19.5 on Saturday at 4200 rpm. I have put the Smart Tabs on it, 60 lb?rs on the 5th hole.
I am new to this, first boat per say. I am not sure if the boat is acting as it should, or not. Don't know if the prop is the correct size or if it may be slipping. I do have an electric trim on the motor.
When I power up, it stands up and then really slowly plane?s out. I use the trim to tilt the motor up until I think I have found the sweet spot but I just don?t know if this is normal or not.
I moved the trim tabs up from the middle but not sure if I know what I am doing with those either. It seems that the tabs are just at the water line when powered up, is this expected?
Thanks in advance for what I hope will be some direction here.
