Well, I'm new to this forum, and I did a quick search for my problem, read through quite a few posts to no avail.
Well heres the issue, we just bought a 89 wellcraft with a Yamaha 115hp V4 Precision Mixture 2 stroke outboard, and were having problems with the oil pumping from the main 11 quart tank, into the smaller tank mounted under the cowling of the motor.
My question is, is there a pump in the main tank that can be replaced? or is there something else i should look into to figure out why oil doesnt pump from the main to the motor mounted tank?
Also does the main tank pump directly to the motor, or does in fill the smaller tank?
The motor runs great, but it seems to be running quite rich in oil. And we feel that this pump could be at fault, any help is greatly appreciated.
Sorry, I tried to keep this as short as possible, though there wasn't any other way to, and fully explain my problem at the same time.
