shagnatious
- May 11, 2010
- 15
i just bought a 1986 riviera fiber corp 17'10" trihull. WHICH I CANNOT find anything about online.
the motor i was told is a 1996. LOGOs say mercury tracker 60 pro series.
serial number is 0g253256.
i put it out in water and it ran beautiful for about 2 miles at pretty close to wot. i have no tach. then it bogged down and shut off. we let it set for a min and it fired back up and it would run for a for a while and shut back off. i think it was over heating but not sure. if we ran itdown to idle it would stall. brought it home checked out the water pump. no crackes or anything in impeller. i pulled thermostat out just to see if that would change problem (putting in new it was curoded) but i took it out and it did the same thing but in a lot less time. like 200 yards. We noticed fuel inside the bottom of casing and found broken line going into fuel regulator. replaced it. motor now will only crank full choke and if you bring down the choke it stalls out. now can only trick it to move without it stalling by uping choke and then dropping choke fast and into gear before it idles all the way down. engine puts out a quite a bit of smoke when it stalls out. a little gas comes out of carbs when it stalls.and if i cover any of the intakes on the carbs a lot of fuel comes out and the rpm rocket up.
just wanna know what direction to go on the motor. wife will kill me if we end up with a lawn ornament.
thx
thx
