Well, as some of you may know I have got the boat with 40 hp force on the back. First I had torubles starting it, then I got it going. After maybe a minute of running I noticed that there is no water stream from the 2 pissing holes on the back of the motor. Not even a drop. It is very wierd since the PO said taht it was in the water before it refused to start one day.
Question 1: Should there be water in pissing holes when the motor is in neutral?
Question 2: Is there an overheat alarm on this motor?
Question 3: What can be the cuase of no water - impeller broke? If I had to take he lower unit down, would I see why it is not pumping water? Or I will hayve to statr throwing parts on it?
Thanks a lot and your help is greatly appreciated.
