Re: Help with a '89 mariner 150
that makes since, is this a hard repair or a easy swap in n out
also would this be causing the xtra smoke?
If it is the stator the extra smoke is comming from unburnt oil because the plugs are not sparking correctly and it's not firing on every stroke.
Changing the stator can be intimidating because you have to pull the flywheel. You'll need a Merc or aftermarket special flywheel puller. You can find those on ebay but make sure you ask if the bolt is fine or coarse thread. You want one with a fine thread bolt or you risk splintering the crankshaft. Whatever you do, never beat on the flywheel or use any other type of puller. You can break the magnets or knock them loose. There is also a center hub that looks like you could remove it. Well you can but you shouldn't. It holds the trigger magnets and if you don't get it back in correctly your timing will be all messed up.
When you remove the old stator make some marks that will help you identify how it was mounted. When you mount the new stator put it in the same exact way. Also note which screws came out of which holes in the stator. Sometimes they're differnt lengths and the wrong screw in the wrong hole can foul the trigger.
Do not torque the flywheel down until after you've checked your intial timing and your output at one of the + leads on any coil. If you find you have a low reading at the coil then pull the flywheel back off and rotate the stator one screw hole and re-check it.
If you have a 40amp stator and it's a Merc then you can't really get it wrong. They've put stops on them and only mount in one position.
