dannyual767
- May 15, 2010
- 273
Hello everyone. This is my first post here but I frequent the Stingray boat owners forum. I'm a very mechanically inclined person and I do all of my own wrench turning.
I've done a search on this topic and I found some information but I saw where a lot of people were having issues of engines running too cold.
I just dewinterized my 2004 Stingray 200LX (5.0L carbed Volvo, 220hp) in preparation for summer fun. I replaced the fuel filter and the raw water pump impeller. Oil and filter were changed at the end of the last boating season and I fogged the cylinders. I filled the raw water cooling system with 100% pink, RV antifreeze.
I started up the boat on the garden hose using the Volvo water flush port in the engine compartment. The temp slowly climbed to it's normal 160? mark. Then as I was watching it, the thermostat opened and the temp fell to about 140? and then the thermostat closed and the temp started to rise again. However, this time the temp went up to about 180-190? . After about 2 mins, the temp started to come down a bit but then it started to rise again. When it hit almost 200?, I shut it down.
I checked my garden hose and I was getting good water. Plenty was running out of the outdrive. At this point I wondered if I had installed the impeller correctly. I took the impeller cover back off to confirm the the "fins" were indeed facing the right way. They were so I put everything back together and hooked the garden hose back up.
Upon restarting the engine, it seemed to act like normal running about 160ish. But then, the temp started to climb slowly to 180? and eventually it started to creep up to almost 200 again. I shut it down and took the impeller cover off to make sure that I'd installed the impeller correctly. All appears to be normal. BTW, the old impeller was completely intact so I know that there are no pieces of broken impeller blocking water flow.
Has anyone experienced this before? It seems that it could either be a bad thermostat or possibly something wrong with my new impeller. I need to fix this soon as the big Memorial Day weekend is just around the corner and I've got family coming to town.
Thanks. Danny
Thanks. Danny
