Re: volvo penta engine question
Lady Jessica, is a cool lookin' boat. PP40 makes the point we all must decide at one point or another if it's worth fixing. One thing to check on your motor before anything is the oil cooler. Its the tube like part under the oil filter. If that is bad, it will start mixing oil with water.
And yes, It looks to be an AQ130 like PP40 said. They are fine engines but old and getting tougher to find parts for. His suggestion to go with an OHC volvo is probably the way to go if you choose to repower. But again you'd need the entire engine and exhaust. examples of the OHC engines are AQ125, AQ145, AQ131, AQ151, AQ171. These are all 4 cylinder gas (petrol as you call it) engines that may work in your boat. The diesel motors are not very common in the states.
