Hi, got an 04 250 hpdi that had even compression across the board (110lbs) before i ran her for the first time this season. Got her in the water fired right up, but didnt want to idle. So took her back to shop and drained fuel, replaced the fuel filters, and fired her back up. Still no idle. Pulled plugs to see if they were foul and the were kinda black except for the two lower plugs on both sides that looked as if they were not as oily (kinda light brown). While i had them out figured what the hell pull a comp test. All were at 110lbs except port center cylinder had 70lbs. Im guessing thats why she doesnt wanna idle. is there anything anyone can recommend?
the boat was sitting for some time (months), what measure should i take.
Anyway to bring that compression up other than rebuild
Thanks
Thanks
