mstaylor77
- May 10, 2010
- 2
Hello,
I have a Mercruiser 5.7L 350 Mag alpha one. I started my boat up this year and had a couple of engine problem that I have been able to correct by reading similar post here on iboat. However, for my current problem I have not been able to find similar problem. This all started with my engine would idle fine in the driveway with muff and once in the water would stall out and would not run under 1500 rpm. After reading a couple of posts online, I replaced the following. Water/fuel separator, fuel filter, spark plugs, and cleaned/rebuild carb. After all this, the engine would start and idle great. My latest problems are; it is burning more gas than before. When I turn the engine off it will keep running. I sometime have to turn it on and off 3-4 times before, it will stop running. I?m not sure on where to start checking for possible issues. Thank in advance for all your help.
Michael
Michael
