Hi guys. I have an '82 Johnson 25 HP that has ran well for the 3 years i have had it. At the end of last season i noticed a light tap/knock coming from the powerhead. It runs fine and had no other problems but was concerned that it could have sloppy internals. I checked piston play thru the spark plug holes and found no play that i could recreate time after time.
Long story short, i am impatient and found another motor for the boat so i could tear this one down. I have it all apart except the pistons have not been removed from the rods. The seals , bearings, crank, rods all seem very tight and in good condition. Measured journals and all are the same diam w/ no apparent wear, discoloration or corrosion.
Did i make a mistake by tearing it down? Could this light tap/knock normal and i just did not notice it before? The '83 Johnson 25 i am running now does not have this sound. Any help appreciated
