Re: 35 hp Johnson Lean Sneeze / Pop causes
Well here is an update because it has been a while. I finally decided to rebuild because of piston scoring and other misc possibilities.
Ive finally got everything rebuilt and ready to drop back in the motor. Everything went ok and some better than I expected. Took me a long time but reading and re reading the service manual along with patience gave reason as to why its taken so long. No real difficulties but a couple of concerns that I hope will not be problems.
First, when I replaced the lower crank seal, I had to use a punch to drive out the old one. What I got as a replacement part apparently replaces that seal and has a different design and made out of rubber. I believe I had installed the correct way but the instructions didnt specify the correct direction. I installed both the upper and lower crank seals to have the cupped side face the center of the shaft.
Second, when I applied the gel sealant to the grove in the crankcase and bolted the crankcase to the cylinder case, will it be a problem if some of that gel sealant oozed out on the inside of the crankcase. Will that eventually be able to work its way out because I was told that it will not dry or harden.
And finally, my manual told me to temporarily reattach the flywheel and turn it so make sure there is no binding. When I did so everything moved smoothly but it was a lot more difficult to turn the wheel compared to before. Is this typical? Also before I rebuilt, when I would turn the flywheel, it would "release" a little when the crank is at the beginning or end of its cycle. So to explain this better, I would have to turn the flywheel about 120 degrees and then it would almost automatically (like spring loaded) turn the remaining 60 degrees by itself. Well after this rebuild it doesnt do that at all and needs a constant torque to turn it. Is that normal?
I plan to start it up this evening so hopefully if all goes well I will have a video for everyone. Thanks for all the help and support everyone.
