quikstang347
- Jan 22, 2009
- 31
Ok I have spent days reading and testing everything that has been posted on here about the precision blend system. I am very mechanically inclined and have not found the issue yet . here is the sympton
Just purchased a flats boat and it runs great i have no issues at all . after a few moments i decided to rev it up and get her moving. it ran great , after about 3-5 mins of 3/4 throttle it lost power and alarms went off. i thought great i blew it up . turned the key off waited a few seconds turned it back on and walla it started and we continued on. keeping an eye on it i thought it was an overheating issue . so having no knowledge of the maintenance of the boat i brang it home pulled the lower unit installed a new impeller. removed the heads and descaled the water jackets, (they were like new) . installed new head gaskets and continued. thought i had it whipped. took it out again and the same thing happened only above 3/4 throttle . this time i noticed that the oil was showing low on the yamaha digital tach (no buttons) turned the key off back on and good again. when i got home i checked the filter for the inhull tank. checked the operation of the pump by removing the oil tank sensor on the engine , alarm works pump works. no matter what i do it will not read full oil , even if i pull sensor and manually move the sensor to read full. the gauge still reads yellow . just removed the tank in the hull (remote) and flushed it checked the sensor and no luck again. i did notice tha the sensor in the remote tank when removed was below a c clip and did not have much room for travel. everything operates and functions well. i just need it to show full oil on the gauge . any help will be much appreciated.
the engine is a 1996 s130trlu
yamah precision blend intact and functioning.
no issues other than the alarm . oil tank is always full just not reading full
