1989 Johnson 60 hp wont start
bs1017fishing
New gas, new spark plugs, new battery, cleaned carbs, compression test and all cylinders are between 120-125. Checked spark outside and was getting good spark to the block. Spark plugs are soaked with fuel but it just wont start. Any help will be greatly appreciated, Thank you
bktheking
Re: 1989 Johnson 60 hp wont start
Describe your starting procedure please.
bs1017fishing
the motor hasnt ran in almost 3 yrs. gas tank was empty. put all new fresh gas and oil in. cleaned carbs but was wondering about the high and low speed jets. are they fixed or do i have to adjust them. sounds like it wants to fire but just wont
bktheking
You can't and they need to be clean, did you remove the screws for the orifices and clean the crap out of them? Did you remove the welch plugs and clean behind. Did you buy kits to rebuild them?
bs1017fishing
I have cleaned them 3 times and removed everything but welch plugs but i was told i didnt have to. it almost seems like im getting too much gas. I have taken apart VRO pump and cleaned and everything is working from pump to carbs. It just seem like im getting too much gas.
