trobinson017
- Sep 12, 2004
- 183
Hi fellow boaters!
I normally boat with my bimini stored in the upright, angled position using rear braces to keep it at about a 45 deg. angle. When I'm cruising at mid to high speeds the whole bimini unit violently shakes left-right-left-right. This has caused the screws that hold the mounting locks to come loose. One even ripped right out of the gunwale! I've reinforced those points but I would like to know if anyone has found a way to stabilize the entire bimini unit so the shaking doesn't happen. Maybe some sort of cross-beam piece or some other, additional bracing? I'd like to keep it in this upright position for several reasons rather than just disconnect the rear braces and lay it down toward the stern.
Any ideas would be greatly appreciated.
