Conversion 1998 25Hp Johnson
Hello,
I am new to the site. I recently purchased a new 1999 Johnson electric start motor. Unbeatable deal in that the owner never ran it. Anyways, I am interested in finding out if I can upgrade the motor to a 30 or 35 hp with modifications. I have converted an older 9.9 johnson to a 15 by doing the carb work on it but have no idea on this motor. thanks for looking and any help.
wilde1j
Re: Conversion 1998 25Hp Johnson
Why didn't you just buy a bigger motor?
CATransplant
I don't know. Why not run it as it is for a while and see how it performs on your boat. What kind of boat do you have, and what's the max hp listed on the transom tag?
restornator
the 35hp was a 3 cylinder that year. There was a detuned 25hp 3 cylinder as well.
There was also a 20 25 and 30hp 2 cylinder line. With a 30hp jet drive labeled as 28hp, and a 20hp jet drive labeled as an 18. Carbs and intake mainfolds were the primary difference. the 20's and 25's had the same intakes and carbs for the most part
CATransplant
Sounds like we need a model number to make sense of this question...
ondarvr
There's about a 30% reduction in HP with a jet, so the 2HP reduction you note doesn't look right. A 30 would be around 20.
They did start to uprate the advertised HP on some jet models though, the 90/60 was labeled a 90/65, no changes other than in print. Looks good to market the HP 5 higher than the competition and it costs nothing to do.
well I didn't buy a bigger motor because it was a package deal. I have a guy at work who's wife bought him this boat, motor, trailor, combo fully rigged out for xmas that year to duck hunt out of and fish. The man never took it out of the garage. the rig is new and never been in the water. I had to knock the spider webs off it and wash it down. This boat is new just a 1999 model and never had a tank of gas ran through it. It is a 1542 war eagle boat. Hope that answered some questions. This was a diamond for sure. With this years same set up it would run 10k and I picked it up for 3500. I put a new battery in and the motor fired right up. Tires still have original sticker on tread LOL. Any ways, I was fishing with it and had 2 other big guys in the boat and the boat dropped way down in top end when loaded down. I do hunt with it and so thought the extra hp would be great when loaded down. The motor is not a jet drive but prop driven. All my friends want to buy the boat but I think I am gonna keep it.
The model number is J25TEEEE serial #G04533219. Thanks for help.
tashasdaddy
screwing with this, is a good way to ruin a good motor.
ondarvr
I don't think he meant you had a jet, just that there were several option for motors in that time frame.
The normal answer is to sell the motor you have and get a bigger one and it applies in this case too. Its typically easier and costs less.
wilde1j
I would sell the 25HP and buy a bigger motor. Way less hassle.
don't quite understand why you say screwing with it would mess it up. The 9.9 to 15 conversion was just a carb exchange as they were basically the same motors. It was my understanding that the 25 and 35 was the same except for carb and linkage also.
blimp
CATransplant
That boat is rated for 25hp max. Trust me...it will perform just fine with the 25hp. Increasing the horsepower will exceed the ratings for the boat and be dangerous. I'd just stick with what you have and go fishing.
