Yon'der Horizon
- May 21, 2009
- 29
Hey guys,
Having some electrical issues on my 1990 Stratos w/ an Evinrude 200XP(1990). The main issue started when the trim/tilt went out randomly. The warning horn (right next to the key-switch) started making random scratchy noises, like it was shorting, then the motor would kill and all power would be lost to the motor including the trim. Typically it would come back randomly. This time she's out for good. We were heading out on the water to troubleshoot this issue. It started right away. Horn made scratchy noises, then turned to a solid beeeeep. We shut off the motor because it was so obnoxious, and the power never came back. I know it's a faulty horn warning because everything is in check (ie. oil level, temp, etc.)
So I am wondering if the warning horn serves as a fuse of sorts. In that if it is shot, the ignition system is shorted. On the water I tested the temp. overheat wire by grounding it to the block and didn't get a beep like it usually does. Should I be looking at replacing the horn?? Thanks in advance for your thoughts guys! Tournament season is right around the corner!!
-Aaron
-Aaron
