Well, this is my 2nd used motor since last October that supposedly ?runs great!?. But after investing much time and several hundreds of $$$, it still looks like I?m not going to make it to the lake. Hoping someone on this site might have an idea of what is going on ? neither of the two ?mechanics? I had come to hear the motor were able to tell me very much.
I have 1994 Mercury, 60 hp, 3 cylinders. It had oil injection, but that has been disconnected, all lines plugged, and the pump drive shaft removed. (Drive gear still on crankshaft though.) New water pump works fine. Engine is on boat and currently runs in a big garbage can. It starts fine and idles okay, (a bit rough, but doesn?t nearly stall). Problem comes when accelerating. Above 1500 RPM there is a metallic clunking sound coming from the power head. It sounds as if there?s a piece of metal loose inside, bouncing around. Engine vibrates / shudders along with the sound ? not dramatically, but I can feel it as I am working the throttle by hand. Perhaps a couple of people hitting the engine block with hammers is a better way to describe the sound / vibration. None of this seems to affect engine power, nor does engine appear to be misfiring / breaking up. The clunks are louder as engine speed increases: I don?t dare go above 4000 RPM. There is no rhythmical sound to the clunks. Surprisingly, after more than two hours of combined run time for test purposes, there has been no noticeable change or deterioration in engine performance. I would think a bad bearing would have chewed up the crankshaft or connecting rod in that time.
So, anyone have an idea as to what is going on? The noise is definitely coming from the power head, and it's the same with the lower unit off the engine. One mechanic who heard it told me to launch the boat and try it in the lake, that under the load of a propeller, any ?sloppiness? in the motor might be absorbed and I may not hear it anymore. I tend to doubt that though, and the nearest lake isn?t all that near. Besides, just because I may not be able to hear it any longer doesn?t mean I won?t blow the engine out in the middle of the lake somewhere.
Anyone ever have a similar problem? Any thoughts on what might be causing it? All responses appreciated!
