loco
- Apr 25, 2010
- 154
Hello all!
I've got a Penta 205, when you crank it from cold it will kick in every time, but if you stop cranking too soon it'll stall and then is an absolute pig to start. We tried leaving it for a good half hour, then cranking with zero throttle and moving up. It doesn't even splutter.
The only way we've been able to get it started at this point is to literally hold the starter on and have it crank for an absolute age - maybe 1.5 - 2 minutes. This obviously isn't doing our starter or batteries any good.
Eventually it will kick in, thereafter, it runs absolutely fine with no problems. Starting it when it's warm is also fine.
Has anyone experienced this before? What could be causing this?
Also, does anyone know where I might find a service manual for this engine?
Many thanks in advance for all your help,
