Re: 1975 9.9 johnson sea horse
One other thing that you MUST be careful about, is if it is a saltwater motor, the cylinder head bolts may be rusted/siezed. I broke one off and almost had to trash the whole powerhead because of it, luckily a drill press and helicoil later and I saved the motor. If you can, let some PB blaster sit on the bolts for a few days, then if you cant get an compressor air gun to each bolt, pull the powerhead so that you can access the bolts with it. You are much more likely to snap a bolt off by using a wrench to remove the cylinder head. Do not force the bolts loose, if they wont come loose pull the powerhead. TRUST ME you dont want to learn the hard way like I did.......
