grumpy armenian
- Apr 24, 2010
- 6
I've just bought a 1984 sea ray srv260 with a 7.4 litre engine. engine was overheating under load even at idle speed. At idle on the dock, temp was on 1/2. After some investigation, found out that on bravo one outdrives the raw water pump is on side of block. Replaced pump & housing, the impeller was no more, it came apart. The previous owner said they kicked up sand & overheating began when they were wide open throttle. So replacing the impeller & housing should have fixed it but the same symptom exist. Still the same scenario, still not enough water circulating through the block, took off hoses from the thermostat housing & the flow was sporatic at best. Head gaskets????Need ideas please. Thank you.
