I bought this garage queen last may. Addressed several issues and in the end, replaced 1 switchbox,impeller and a couple seals, trigger, plugs, and carbs rebuilt, TWICE but thats another story. Fuel line, filter, pump, bulb and most of the hoses under the covers have been replaced. I have a chronic problem that I'm trying to figure out and I need y'alls help. When I am at a stop and push the throttle 100% open, or even part way, there is a hesitation of up to 3 or 4 seconds before a somewhat normal accelleration takes place. I have been told that in replacing the 1 switchbox and not the pair that they don't work together properly. I also wonder if the carbs are properly set up. Dealing with motorcycles years back, their carbs were balanced using a metering stick so that their vacuum was equal.. Do these carbs have to be set up the same way? There are times that the hesitation isn't as bad as others, but that isn't understood either.There is always some hesitation. Motor runs good once it gets past this hesitation and turns 6200 wot. New needles and seats in carbs, and second rebuilder soaked them for 2 days to get the accumulated funk out. Motor starts reliably and idles ok, but does seem to load up sometimes. when trailering and using the throttle to get it all the way on the hesitation is a real pain. Any help would be appreciated.
