I have a mid 80's Force 85HP that has been really reliable, except.....a strange starting issue once in a while. And it always seems to happen as follows:
When I first put it in the water it starts right up, usually first, maybe at worst second turn of the key.
It then runs great all day until the gas tank runs out, and the engine stalls because of no gas. I switch to the next tank, pump the ball, and sometimes it starts right up, sometimes it takes 5, 6 7 or 8 tries or more!
The strange thing is when this happens if I tilt the engine up out of the water it usually starts right away.
Also, if I turn off the motor before I run out of gas and switch tanks it starts first time every time.
So the problem is obvious...when the engine runs a tank dry it is harder to start back up.
The questions then are:
Why does it usually start easier tilted?
What should I look at first that might help the re-start issues?
Fuel pump? Diaphragm?
Thanks for any suggestions.
