jtaylor1101
- Apr 4, 2010
- 3
i am new to outboards and have been fighting the 1983 75 chrysler i bought. it had been sitting for a couple years and i got it running however i replaced the impeller and cant tell if its working properly. i havent run the engine longer than 20 seconds or so cause i dont want to overheat it. Its my understanding that at idle there should be water coming from the two exhaust holes on the back under the cowling. there isnt a drop coming out, am i not giving it enough time, is there possibly a blockage somewhere, if so where should i check. or does the water come out somewhere im not looking. BTW i am running it on muffs with the water on high. please help
also i just went out and removed the thermostat and it is completely dry inside, i also started the engine and nothing came out from either hole where the thermostat goes
