I have read about the throttle cables needing lubrication, I have a merc Quicksilver unit monted next to dash, I removed the trim cover from the top and I can see some linkage and some white grease has been applied, I could do that easy enough, but I thought the cables themselves had to be lubricated, I went under the dash and found the cable ends they appear to go straight into throttle control thru long sleeves that don't look like they can be lubricated. Does the throttle control end get lubricated?
Thanks
Thanks
