tractoman
- Jul 16, 2009
- 370
Re: Used boat buying guidance needed please
My 4.3LX runs about 145-150 most of the time, my oil pressure is about 50 psi. Did you check the oil and how did it look? Could be a not super accurate gauge. You could always confirm with a mechanical gauge to be sure the gauge us correct.
Not sure about your water. I've had gallon come pouring out the plug before, but its the kids in and out of the water, and the damn tube that always seems to retain a bunch of water whenever I haul it in. I don't think a little water is too unusual. My bilge pump has never came on either but it works and there is a float switch that also works. Do you have a float switch for the bilge pump?
Is the bilge are clean or oily? You may have just rinsed it out a little.
