Kitchen363
- Nov 21, 2009
- 80
So I've see a few boats that have underskin installed on them. Really like the idea of not having the wake, beat the heck out the bottom of the boat. Water will even splash through the table pole hole in the floor.
Anybody ever done this themselves? What thickness aluminum was used? Where can you buy large sheets of aluminum (in the Cincinnati area)?
Do you have to break the edges of the sheeting down toward the logs or just install a flat piece.
My first thoughts are to overlap the sheets back to front, drill a 1/4" hole in the sheeting and drill and tap the frame of the pontoon and attach the underskin with a 10-32 stainless steel truss head screw. I'm thinking I want the underskin to be removable if I ever need to access the decking bolts underneth to tighten them in the future.
Also I use a up-down lift type trailer of haul the boat dose this pose any unknown risk?
2006 Bentley 200 cruise
90 hp Mercury 4 stroke
