Re: Trailer bunks
If this is a flat-bottom boat and you want a good longterm solution, try welding angle-iron (or the aluminum equivalent) onto the trailer instead of bunks. Then, bolt PVC boards to the angle-iron. The angle-iron provides the support needed, while the PVC boards provide protection for the hull and make it easy to launch/load the boat. You can also use composite lumber in lieu of the PVC, but it will get moldy over time.
