Re: Windows 7
Your office program didn't work because you didn't get the ultimate, which has backwards XP compatibility.
I don't think it's just Ultimate. I'm running Home Professional and it has the ability to emulate previous versions of Windows through the Compatibility Wizard. The OP, wvmedic, states he's using win 7 home, but doesn't specify Basic or Professional. The feature may well be included in Home Basic as well - I don't know.
I'm not currently running microsoft office because my old office will not work in win 7.
Have you tried using the compatibility wizard in Windows 7? You may already be aware of this feature in 7 and if so don't bother reading the rest of this post, but 7 can emulate any previous version of Windows to allow most programs that are otherwise incompatible with 7 to run normally. I'm always hesitant to make assumptions of an OP's level of knowledge as an explanation that's meant to be helpful could be construed as insulting, though, in case you were unaware of this feature, here's how to access it,
Right click on a program icon and you will have these choices,
Choose "Troubleshoot Compatibility"
And you have a choice of letting 7 make an attempt at choosing emulation settings or manually choosing the settings based on what type of problem or incompatibility notifications that you are seeing.
If you choose, "The program worked in earlier versions of Windows but won't install or run now," then you'll be able to choose which version of Windows to emulate.
Using emulation I've been able to keep using a number of programs that initially wouldn't run under 7. Hope this helps,
