steamking123
- Aug 8, 2009
- 42
I am trying to disassemble my lower unit to get to the clutch dog and the gears. I read over the manual and then tried to do it it. Reading that manual is reading a language that I don't speak. I swear they are giving instruction for a different lower unit so I thought I would ask you guys for some help.
Here are some pics to where I got.
[/ATTACH][/ATTACH][/ATTACH]
I started by draining the oil, and loosing screw to the shift rod connector behind triangular plate half way up the shaft. Then I removed the 8 bolts that connect the lower unit. Lower unit slip down about an inch and a half to expose the drive shaft and the shifter rod. I also tried to remove the 8 bolts the connect the middle section of the shaft but 4 of the bolts broke off at the head.
What do I do next to completely disconnect lower unit from motor.
I also tried to get to them from the propeller with no success. There appears to be a clamp of some sort.
Which way should I be going to examine the clutch dog and the forward gear.
Thanks for your help
Derek.
More pics on the way
Derek.
