Re: 1986, 85 hp, stubborn bolts on fuel pump
There are six screws on the Fuel pump. 4 of the screws actually not only hold the fuel pump together, they also attach the pump itself to the bypass port cover. If the problem is with one of these screws, then you shouldn't have any problem using an impact screw remover. The remaining two only hold the two halves of the fuel pump together. Probably not a good idea to start whacking on these two because there is a possibility you may actually crack the fuel pump itself. There is no support under the fuel pump where these two screws are located.
If it were my motor, I would change it. If your motor happens to run lean from a bad pump, there is a possibility you can do some damage to the pistons. Plus you'll have piece of mind knowing that it's been changed.
Note: Using heat is probably not a good idea. Heat + gas = BOOM. Also bad for the diaphragm, paint and the check valves in the pump. Each check valve (there are 3) has a disk that may be plastic or similar material.
