Re: 58' johnson hp
looking for some help with my old johnson 3hp twin. My father had it since i was a kid and although I started it 3 or 4 years ago it has not run since. It wont fire, although I have lots of spark no fuel is getting to the cylinders as plugs remain dry. I've removed, soaked, cleaned and blown out the carb. The float and needle seem to be working and fuel bowl is full but I do not know how fuel is pumped or drawn through carb so I do not know what to look at next. Can anyone enlighten me.
thanks
If the carburetor is filling up with fuel the problem is elsewhere. But if it is NOT filling up, the sintered fuel filter in the gas tank is probably plugged with old gas gum. They are virtually impossible to clean--replace it. After cleaning the tank that is.
OOPS!!!, you said the bowl is full. If that is true and you have the lower knob open about a turn and the upper one about 1-1/2 turns, and are choking it, and it won't fire, it isn't a fuel problem.
Define "lots of spark". Will it reliably jump a 1/4" gap? Those motors are notorious for developing cracked coils with age. They have fooled the best of us, thinking it has "good" spark. I believe you can remove the recoil starter and the thin plate off the flywheel and look in and see the coils. If they are cracked, you are wasting your time till you replace them.
The plugs SHOULD be dry. If they were wet, the engine would be flooded.
BTW, Check your compression. Should be around 80psi.
