I have a 2 year old bow mount minn kota 80lb thrust motor with the following problem...
I step on the spin the prop button on the foot pedal but sometimes the prop doesn't spin!
1. The red arrow directional light always comes on when I step on the spin the prop button
2. I can get the prop to spin by stepping on the spin the prop button like 50 more times. Once out of 50 tries it usually will work.
3. A better method to get the prop to spin is to step on the pedal up and down to rotate the trolling motor shaft right and left and then retry the spin the prop button
4. When I toggle the on or continuous on button to either setting, sometimes the prop spins and sometime not. (when the switch is set on spin constantly sometimes the prop doesn't spin)
Any idea how to trouble shoot this frustrating intermitent issue???
It just rained recently. Could it just be a "wet" switch???
Batteries are charged and terminal connections are good.
Thanks in advance
Brent
Thanks in advance
Brent
