Re: 1975 Johnson 15hp motor
If my water pump is working properly should I even take the lower unit apart, it seems to be working fine and pumping out water, I just changed the gear oil, is there anything else that I should be looking at?
Thanks,
Kyle
I think the kit vs impeller is more a remove and inspect deal although if you buy the kit you are replacing all the potential issues that can occur instead of just doing the impeller. Just doing the impeller is cheaper. Pull it apart and inspect. The pump grommet at the top can fold over, the bottom plate can wear, the inside of the pump housing can wear. If it all looks good from visual inspection why waste the money on an entire kit, that's my logic. IBOATS does sell the impeller by itself, Sierra p# 18-3050.
Thanks,
Kyle
