untamedmind0211
- Mar 6, 2010
- 7
I posted a few days ago about my 1972 evinrude 50hp and I asked whether it was worth fixing or not. It turns and everything, just wont start. It ran a year or two ago, nothing catastrophic happened to render it non-operational. It just sat and now wont run. I've checked out the motor some more and here's what I've got:
Compression on the powerhead was within specs, same with the parts motor.
Fuel pump was disassembled and it was pretty shot
Carbs will definately need rebuild
wiring harness from controls to engine is in good shape
engine wiring harness needs replacement, but I have a spare
coils look blown
tested shift solenoids with multimeter, everything seems good
stator and timing base seem fine, tested with multimeter
lower unit will definitely need new seals
So, from what I can tell, I'll need to rebuild carbs, buy coils and lower unit gaskets. Also need new fuel pump and fuel lines. Controls are frozen, but I am probably just going to replace it with an aftermarket unit and make my own electronic shift control. I'm pretty good with electronics and have already drawn up the schematics.
Taking all this into consideration, would you say its worth it? Is there anything else I should know or check for on this particular engine?
coils look blown
