hwsiii, I actually posted this same information earlier under a different title and received some help from some great guys, EZEKE and especially Trendsetter240. I hope they won't take offense if I put this by you as well as I have noticed that everyone seems to come to you as the foremost expert on these questions. I have also updated some of the information that was previously incorrect on the form. Any knowledge you could share would be greatly appreciated. Thanks, D
Iboats Boat and Motor Info
1. Year, make and model of boat
2001 MCKEE CRAFT BACKWATER 172
2. Length, width and base weight of boat, look for boat decal on back of boat
17'2" 80" 1250LBS
2a.What is the maximum recommended HP for your boat
115 MAX HP
3. Number of people and gallons of gas normally on boat
2 ADULTS 25 GALLONS GAS
4. What do you use the boat for
CRUISING--FISHING
5. Is it a Deep Vee and if so how many degrees of Deadrise
VEE HULL---16.957 DEADRISE
6. Year, manufacturer and model of motor
2001 JOHNSON 90HP OCEAN PRO--J90VLSIF
7. HP and gear ratio of outdrive IMPORTANT
If you don?t know the gear ratio, you need to pull the plugs out of the motor and put a piece of tape across the prop and the lower unit and then cut it between the prop and the housing then do the same thing on the flywheel and turn the motor until the tape lines up with each other on the prop, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
90HP--13:26 (I BELIEVE THIS IS 2.1 RATIO)
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
4500 - 5500
9. Anti-ventilation Plate height above the bottom of the transom of boat if it is an outboard in inches, use a straight edge or a board under the keel and sticking out to the anti ventilation plate for a reference, and take about 4 pictures for us to see.
2 3/4" ABOVE THE KEEL.
Is it a bass boat or does it have a pad bottom and is it on a bracket, if so how far does the bracket extend from the stern.
NO---NONE OF THE ABOVE
11. Does it have a hydrafoil, dolefin, whale tail or trim tabs and is the motor on a bracket, and if so how far back from the stern is the bracket
12. Manufacturer, model, diameter, pitch, number of blades and whether SS or aluminum props.
IMPORTANT
1.MAKE: STILETTO- MODEL: ADVANTAGE I,- 13 1/4X17,- 3 BLADES,- STAINLESS STEEL
2.
3.
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. Make sure you trim the prop up until it starts ventilating and then just trim in until it quits ventilating. If you do not have a tach you can buy a Tiny Tach for less than $ 50
RPM 5100-- Speed (GPS) 42 MPH--No. of people 2 ADULTS Gal. Gas 20 GALS
14. Are you at sea level or a higher elevation, give us the elevation in feet SEA LEVEL
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way by only using the control on the console, checked compression, looked at the plugs and checked spark, is the bottom of the boat clean and barnacle free, and have you checked the Tachometer against a mechanics tach, all of the foregoing could be the reason your prop is not attaining full RPM.
BOAT TUNED UP AT THE END OF SUMMER--BOTTOM VERY CLEAN---NO TO CHECKING AGAINST MECHANICS TACH BUT I USED THE TACH THAT CAME ON BOAT AND A BRAND NEW FARIA TACH AND GOT IDENTICAL READINGS.
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop.
JUST PUT ON FOR THE TEST RUN---NOT SURE IF IT IS THE RIGHT ONE OR NOT. I JUST REMEMBER HEARING SOMEWHERE THAT THE RPMS SHOULD BE CLOSER TO THE WOT RATE OF 5500.
17. Does the prop show any damage that you can see
NONE---IT IS A BRAND NEW ONE AND IS PERFECT.
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
I AM HAPPY WITH EVERYTHING BUT I AM WORRIED ABOUT NOT ATTAINING A HIGH ENOUGH RPM AS I WANT THE MOTOR TO RUN AT ITS MAXIMUM EFFICIENCY FOR THE MAXIMUM LIFE AND HEALTH OF IT IN THE LONG TERM. I ALSO WONDER ABOUT PROP SLIP.
19. If you are trying to attain a better cruising speed and fuel savings or trying to attain a faster speed I will want you to take your boat and run it with 1 or 2 people and give me the RPM and speed readings starting at 3,000 RPM in 500 RPM increments all the way to WOT.
1. 3000 RPM
2. 3500 RPM
3. 4000 RPM
4. 4500 RPM
5. 5000 RPM
6. 5500 RPM
7. 6000 RPM
REMEMBER, The prop I recommend will be NO better than the information you give me.
17'2" 80" 1250LBS
115 MAX HP
CRUISING--FISHING
4500 - 5500
IMPORTANT
2.
3.
1. 3000 RPM
2. 3500 RPM
3. 4000 RPM
4. 4500 RPM
5. 5000 RPM
6. 5500 RPM
7. 6000 RPM
