Re: T/T bleeds down
me again,if the piston/cylinder is not leaking you may need to bleed air and add fluid to t/t.to bleed it first make sure the manual valve is closed, clockwise to close. its on the bottom left of the pump/motor you can see the access hole in the engine clamp bracket,bottom left near the hole for the shaft that holds the bottom of the t/t unit.to bleed, trim all the way up,then remove the filler plug in center of square pump housing (faces backwards toward eng).if fluid runs out its full,if not add. my 03 F90 takes dexron 2 trans. fluid.you may need a small hose and funnel as the filler hole is smallish.fill till it spills out and replace plug. cycle t/t down/up all the way 3 or 4 times ,then repeat raise/plug/fill/plug/cycle until fluid spills when you unscrew plug,then your done and it should hold position.you should see eng.rise higher each time you bleed/cycle t/t as fluid goes in and air comes out.if its not leaking @ piston,and bleeding is not helping then you may have leaking inside the valve ***.there are alot of o rings in there.Randy
