Re: 1971 60hp won't go into gear
OK, I've taken the controller apart and it all looks fine (but the switch is a sealed unit that I couldn't take apart to check the connections). Attached water to the engine, switched on and it all works fine. Forward, neutral, reverse all functioning as they should.
This leaves me with a bigger problem, why didn't it do that yesterday in the middle of the sea? I started the motor several times and tried to move, but each time it didn't go anywhere. Is there anything in the drive to the prop that could work at low revs in fresh air but not transmit power under load in the sea -or was it an electrical glitch? Can anyone point me to a supplier for a new switch for the control unit (or a part number I can use to trace one). If it was an electrical problem this seems the most likely cause, so probably best to change the switch to be on the safe side.
If stuck in this position at sea again would just disconnecting the wires lock it in forward drive? (will it start in gear).
