Re: plywood for floor
Big Sky,
You can use whatever you want. My argument is that the marine plywood is much better made that the cdx or exterior grade stuff. There are no voids, it's a minimum 5 plys making it stronger and the glue used to laminate the plies is waterproof. That coupled with the smaller amount of resin needed makes sense to me. I keep telling everyone that I installed the foam tight to the top of the stringers (that's what I call em) and went back with the 1/2" which was what came stock, sealed it with resin and did a layer of fabric and two layers of resin on top and I don't have any weak spot issues.
Remember, if you have side panels, you'll need to adjust the height if you remove 1/2" and go back with 3/4".
