I have a 1977 mercury 85hp inline 4 cyl. The carbs have been cleaned and have new gaskets and needles and seats. The compression is around 140psi on all cylinders.
The problem is that it will idle fine and will run up to about 5mph and no more than that. It will rev up out the water on the muffs but not in the water.
Any ideas will be much appreciated.
(Edit)
I tried adjusting the carbs and found that when I make adjustments on the lower carb the engine does not run any differently no matter how much I adjust the set screw in or out, but the adjusting the top carb will make significant differences in how it runs. So I am guessing the lower carb needs to be removed and reinspected. Could the float height cause this problem?
(Edit)
