I have 1997 twin 225 hp Yamaha 2 stroke motors. with low hours which I bought new. They are EFI. I am having a problem with the Port Engine. It starts and idles as long as I hold the switch on - when I let go of the swith the motor dies. Could it be the ignition switch or the kill switch? It did this two years ago and I replaced the wiring harness but that didn't make any difference. A month or so later, it started working again but now it is doing the same thing. The engine oil tank stays full, the engine is in a vertical position and I have switched oil tank assembly from one engine to the other which didn't make any difference. Would appreciate any input or suggestions.
