Having a problem removing the lower unit to inspect the water pump for possible replacement.
Was able to remove outside and inside doors to remove lower screw on shaft. Soaked 8 bolts with penatrating oil and got 5 out clean, but 3 bolts snapped at the thread line about 3/8" from top of bolt. So, I have 3 threaded studs remaining that are holding is holding the lower unit to the motor.
Is it possible the lower unit can be removed in this condition, then back out the broken bolts/studs?
I plan on replacing the hardware once I button this back together.
Thanks
Thanks
