johnnyfitz
- Feb 20, 2010
- 7
I have 2 175hp motors doing the same thing. They were sunk so we had them took to a dealer and cleaned.Worked fine for a while and started acting up .The motors go until they heat up and shut down and check for fire right away and there is none.I changed the stator on the engine and it went for awhile and started acting up again. I was told it could be the voltage regulator!!!Anyone know if that could be my problem.Could it be my power packs on both engines and if so is there a way i can test them before i buy 2 and that is not the problem.If that happens i will sink her for good LOL!!!!Would a bad coil make her shut off and have no spark at all.Any information would be gratefully appreciated. Thanks!!!!
