Anyone else having this problem? My pair of 2005, Yamaha 250 four strokes are making oil. Two oil analysis test have confirmed fuel in the oil. Changed thermostats, plugs, fuel filters, oil and oil filters at 300 hr. service. Nov. '09 did a leak down test; 2 cylinders failed on one, and 4 on the other. Treated problem with Evinrude power tune. Changed plugs, oil and oil filters. Repeated leak down test. All cylinders passed! This significantly improved the fuel in the oil problem, but it is still happening to a lesser degree. My Yamaha dealer repeated the leak down test. It passed again. The dealer and Yamaha warranty people did not recommend repeating the "decarbon" procedure with any brand of decarbon treatment, because "it could cause more problems at this point". Dealer just changed the oil, and after 8 hours, oil has climbed the dip sticks 1/4th inch. There is a faint smell of gas on the dip stick. (Before the decarb process, gas smell was stong.) And YES, I check the oil with the engines in the EXACT same position and temperature every time. At this rate, I will need another oil change by 50 hrs. I bought this 28' Parker in May 2009 with 210 hrs on the motors. There is now 418 hrs. This is a recreational fishing boat. The motors run and sound great, but the oil changes are getting old. The Yamaha warranty people and dealer agreed to pay for 2 oil changes. They also replaced an oil pressure sensor that was giving false alarms. Now, I am just waiting to see if this problem continues. Maybe increasing the "Ring Free" dose from 1 oz./ 10 gallons to 1.5 oz/ 10 gallons would help? Any comments or suggestions welcomed.
