Re: OMC flush mount control box removal
Still snowing here seon, I can walk you through it if you like given an 88 is the same as 93. If you look at the very bottom ( on your back looking up under) of your control handle 6 oclock position there will be a ( U ) shaped groove cut into the handle, When you put your control handle to full reverse that groove will now be in the 9 oclock position, there is an allen set screw in there pretty sure it was 3/32, 2-3 turns out should be enough to free the handle. now if you have fast idle control ( button in the center bottom of control handle just grab that rubber cup and peel it back toward you and off of the cap. There will be a philips screw holding the white cap on, remove it and the cap and pull the handle off the splines. To remove the control body from the panel pry off the black plastic trim piece ( 3 oclock position) in referance to the spline shaft where you just removed the handle and there will be 3 philips screws, remove them and you will be good to go. Any questions at all I will try and help.
Tom
