Re: Can't drop lower unit
You know, now that we have come this far, you apparently thought you "Had to do it" probably because someone told you that if you didn't change the impeller every six months the world would come to an end.................
When I was a teenager, my daddy bought a 10 hp Scottatwater engine. We had that engine for at least 10 years and the impeller was never changed....fished in salt and fresh water, salt brine and all that "stuff""""""""; churned up a lot of mud in Clear Lake, TX. and Taylor Lake, TX. beins they were so shallow that you didn't need a life vest when skiing. Just fall off and stand up in the mud.
I can't tell you how many times I ran that engine out of the water, with absolutely no water supplied to it for 5 to 10 minutes sitting on a rack in the garage or hanging on the fence at home. Like I said, never changed the impeller and never had an overheat problem. Only problem with that engine was one day I was running the San Jacinto River, below Lake Livingston, N. of Houston, TX. and ran across some old railroad pilings that someone cut off about 6" below the surface.....really made a mess......that is where I learned that 2 cycle engines use roller bearings on the crank-connecting rod interface.
So, what is all the fuss about nothing. Been boating since 1955 and NEVER had an impeller problem, salt, fresh, brackish, saline, mud, sand, you name it.
Current engine is a 2002 with the original impeller and it will pee 2" into the water at idle.
Gimme a break......sounds like the Al Gore fiasco.
And speaking of Al Gore, saw his 100' houseboat today ( I think courtesy of the NY Times or the WSJ) and the jet ski on the stern.....saw no windmills on it, nor any solar panels. I guess he powered all that with his CO2 breath exhalations, but wait a minute, CO2 is now classified as a hazardous gas......any vacancies on Mars? Gimme a break.
Mark and proud of it.
