1986 50hp evinrude
jim bob
Hi, having trouble with power tilt not going up. I have to lift engine while engaging up switch, motor runs but won't lift. Once at the top the engine will fall down to about 2/3rds and stay. I checked oil level and its good. The owner before me has fitted a bigger tilt motor from a 115hp of which brand i can't remember. Any information would be great.
tashasdaddy
Re: 1986 50hp evinrude
Trim & Tilt
With someone?s help push the up button, and someone help the motor go all the way up. Lock motor in that position, now fill reservoir, replace cap. Unlock and bush button to lower motor. Keep repeating until it does not take fluid. The unit should operate now. Dextron II or power steering fluid.
jim bob
Hi, i just tried that and it hasn't changed at all. Any more suggestions. cheers
